We are designing new controller. We are looking for the TPS7B8650QDDARQ1 (5Vdc LDO; fixed voltage) part for low power mode. We would like to calculate the quiescent and ground currents at 1mA load over temperature from -40C to 125C. The quiescent current is less than 25uA at input voltage from 5Vdc to 40Vdc. The ground current is changing as per load current. Our load current is 1mA over temperature in low power mode. What is ground current and quiescent current at 1mA load and over temperature (in worst case scenario)? Do we need to consider the ground current and quiescent current at 1mA?
