Part Number: TPS1653
hi sir
we use the TPS16530 To be the power protect, verify as below
I shorted the TPS16530 circuit output to the gorund, and IC was burn out.
Please help to figure out the problem is.
Refer to the sch. as below:
thanks
hi sir
thanks
Hi Chen,
Do you have waveform?
Because of PCB path inductance and L1 inductor present at output, VOUT can go negative and violate the device -ve abs max.
You can probe the VOUT while doing short circuit to check that. I would recommend using Schottky diode like output.
Amrit
