Other Parts Discussed in Thread: TPS65086
Hi team,
We recently purchased the TPS6508640 to power the Xilinx Zynq Ultrascale+ ZU7–ZU15, as recommended in the datasheet.
In Table 4-1 (Default Values), the datasheet lists the default voltages provided by all regulators. Doesn't it means that PMIC outputs these voltages automatically after it powers on?
Because, we have to reconfigure the registers every time the system powers up, which seems incorrect since we expect the PMIC to output its default voltages on startup.
Is there any way to OTP-program for TPS6508640 so that our configured voltages are applied permanently at power-up? Or is there another process we should follow to make the PMIC automatically provide the desired voltages?
Santhosh
