LM7800: Effeciency calculation
Part Number: LM7800
I used the "LM7805MP_NOPB" LDO in one of my projects, it did work and now I im preparing the power tree, the total power consumption is 5V/50mA and the input voltage is 9V,when i searched for the efficiency formula in this datasheet(https://www.ti.com/lit/ds/symlink/lm340.pdf) i didn't find it.
did i miss something?
  • Hi Mounir,
    Not every datasheet has an efficiency formula written in it.
    The efficiency formula is going to be
    1 - (Output_Power / Input_Power) = Efficiency
    Output Power = VOUT * IOUT
    Input Power = VIN * IIN
    Eduardo Linares
  • Hi Eduardo,
    The ideal case is knowing the efficiency , Vout, Iout, Vin and the only missing variable Iin, but in my case, the efficiency and Iin are missing, so the calculation is not doable with that formula.
    Is there an other way to know the Efficiency,i have the board and the required equipments to measure the input voltage,input current,output voltage,output current, then calculate the Efficiency,then use the Efficiency i got for the formula you sent.
    If im correct that would work right?
    Else do you have any other data that would skip all the hassle.
    Mounir Ben Ali
  • Hi Mournir,
    if the ground current is negligible relative to the output current, you can replace approximate it with the output current. if not, we can approximate the input current by adding the output current to the expected ground current.
    Based on the graph in figure 12, it looks like you should be hovering around 5mA, so you can approximate the input current as 55mA.
    You should be at around 49.5% efficiency.
    Eduardo Linares
  • Hi Eduardo,
    With these values:Iin=55mA,Vin=9V,Iout=50mA and Vout=5V,and using the formula you sent:
    Eff = 38.8888%
    So based on what i understood,my calculation are correct but the efficiency is far from 49.5%.
    Mounir Ben Ali
  • Mounir,
    Can you post your math? This is what I calculated:
    input power = 9V * 55mA = 495 mW
    output power = 5V * 50mA = 250 mW
    250/495= 0.505
    1-0.505=0.495
    Eduardo Linares
  • Hi Eduardo,
    I did the calculation again and your result is correct, there is a mistake somewhere that I didn't notice.
    Looks clear now, thank you for your support.
    Mounir Ben Ali
