TPS388C0-Q1: Power on and monitoring range data corresponding to OTP
Part Number: TPS388C0-Q1
Dear Team,
Does the part number TPS388C06001RTERQ1 have power on and monitoring range data corresponding to OTP?
  • Hi Allen,
    Thanks for your question!
    I'm not sure I quite understand your question. Are you asking for more information about the OTP configuration for TPS388C06001RTERQ1?
    If so, please find some of its characteristics below:
    For further support, can you let me know which part of the OTP you are looking to understand further?
    Andrew Li
  • Hi Andrew,
    If OPT does not meet the requirements, is there any material without OPT available for custom configuration to meet the requirements of project monitoring? Please help recommend, thank you!
  • Hi Allen,
    OTP means the default configuration for each device that is burned into each device. You can change the device configuration on boot-up via I2C, but this device does not have any non-volatile memory (NVM) so you would need to do this on every system bootup.
    If you share some more information about your requirements, I can also make the best recommendation. Based on opportunity size, we can also work on making a custom device to fit your exact needs as well!
    Andrew Li
