I have some difficulties to choose a Schottky diode to protect my LP2986.
Vin is a battery between 0V and 14.7V, I have two LP2986, one @ 3.3V and a another @ 5V.
No criteria really. A general purpose Si diode could probably work as well, but the Schottky was specified to give a bit more headroom.
BAT54, or similar, is a good choice.
If both LP2986 inputs go to common connection at battery (i.e. in parallel), then BAT54-C could be used.
If the LP2986 are in series ( Vbatt > LP2986-5.0 > LP2986-3.3 >) then a diode across each device is required and BAT54-S could be used.
OK thanks you for the reference.
My LP2986 are in parallel.
So, I apply the schematic in datasheet, but i do not understand the operation :
When Vin <Vout (abnormal operation), the diode is blocking? And when to Vin> Vout?
When Vin < Vout (abnormal operation) the external Schottky diode is conducting (ON) and the reverse current flows through the external Schottky diode, and not through the parallel internal parasitic diode/SCR.
When Vin > Vout (normal operation) the external Schottky diode is blocking (OFF).
