Part Number: LMR51440-CALC
Other Parts Discussed in Thread: LV3842, TPS560430, TINA-TI, LMR54410
hello
im trying to look for LV3842 library for TINA
if you have any information, could you share where can i find it
hello
Hello Joonsuk,
You can use the Pspice model found on the following product page:
TPS560430 data sheet, product information and support | TI.com
LV3842 is similar to TPS560430, so you can use the Pspice model of TPS560430 for your simulations.
Thanks and Regards,
Sourish Nandy
Hello Sourish,
I downloaded the TINA-TI model but unable to configure the buck converter to give a 3.3V output even after changing the feedback resistors. Is this how the encrypted models work??
Thank you
Hello Sankalp,
You downloaded the TINA-TI model of which device?
Can kindly state that?
Thanks and Regards,
Sourish Nandy
Also if u can suggest me an alternative component in replacement of LV3842 that can be used in TINA-TI simulation would really help me.
Hello Sankalp,
Can you kindly use the Pspice model for TPS560430 and try to use it?
To Download PSpice for TI, follow these steps:
Thanks and Regards,
Sourish Nandy.
Hello Sankalp,
You can try out the Pspice for TI model for LMR54410 on its product page as it is pin to pin similar to TPS560430.
Thanks and Regards,
Sourish Nandy.
