Part Number: TPS61094
Hello TI Team,
We are designing a battery-powered smart water meter using NB-IoT communication, with a target lifetime of ~10 years.
System details
Battery: 3.6V, 19Ah Li-SOCl₂ (primary lithium)
Supercapacitor: LIC1020, 80F, 3.8V rated
Regulator: TPS61094
Output voltage: 3.3V
Load profile:
Sleep current: ~45 µA
Active current: ~70 mA
Peak current: ~330 mA (NB-IoT TX, ~1 sec/day)
Challenge
We observed that TPS61094 supports discrete charge termination voltages, and there are no selectable values between 2.7V and 3.6V.
This leaves us with only two practical options:
2.7V
3.6V
Concern
If we select 3.6V:
Charging will only occur when battery voltage is near full (~3.6V)
Once battery drops below ~3.3–3.4V, the LIC will no longer charge
This may lead to loss of supercap buffering during mid/end-of-life
If we select 2.7V:
Charging will work across most of the battery discharge curve
However, stored energy in the LIC is significantly reduced (~50% compared to 3.6V)
This may impact NB-IoT pulse performance and efficiency
Questions
For a Li-SOCl₂ + NB-IoT pulse load application, which charge voltage would TI recommend:
2.7V (lower energy, full-life operation)
3.6V (higher energy, limited charging window)
Does TI have any guidelines or reference designs for selecting supercap charge voltage in long-life metering applications?
Is it acceptable to operate the LIC continuously at 2.7V from a performance and lifetime perspective?
Would TI recommend an alternative device (within TI portfolio) that allows:
More flexible charge voltage (e.g., 3.0–3.3V range)
While still supporting ultra-low quiescent current and supercap charging?
Does TI recommend any alternative supercapacitor / LIC / HLC devices or a different power architecture (e.g., passive buffering, different regulator topology, or hybrid approach) that would be better suited for:
Li-SOCl₂ battery
NB-IoT pulse load
10-year lifetime requirement?
Goal
Our objective is to:
Ensure reliable NB-IoT operation across full battery life
Maximize usable battery capacity
Avoid mid-life degradation of supercap functionality
Looking forward to your recommendation.
Thank you.
