Part Number: BQ79731-Q1
I would want to implement a test sequence for the entire over current detection chain.
More exactly we want to directly control the OC1/2 signals. We have tried to achieve this by using OC1_FLT_GO and OC2_FLT_GO.
The issue is that after our test sequence is done, we cannot stop this OC output, as writing OC1/2_FLT_GO == 0 has no effect.
I have also tried to use DIAG_OC_CTRL2, but even after setting this back to 0, the PWM output does not stop.
How could I stop this PWM after checking that it is working correctly.
Thank you!
