Part Number: LM5180-Q1
Hi team,
Could you please advise the tr and tf (rising, falling time) of low side FET?
I need this information to cacluate the power consumption.
regards,
Hi team,
regards,
Hello Shinji,
As these parameters are not available in datasheet, I need to ask these data from design team, will get back to you soon.
Hareesh.
Hello Shinji-san,
Thanks for your patience!
I am following up with design team, but it is taking some time. I will update you once I receive the data.
Regarding power consumption, since everything is internal, why customer require to calculate switch losses / power consumption?
If customer need device power loss, they can find in efficiency graph from design calculator excel: LM5180DESIGN-CALC Calculation tool | TI.com
Also, quiescent / supply current data is given in datasheet, customer can use this if needed. Please find below snapshot,
I will update you once I receive the tr, tf data.
Hareesh.
