Part Number: BQ41Z90
in the BQ41Z90 datasheet I found that SRP, SRN input ranges are -0.25V to 0.5V. However, the ADC 18-bit input range is not specified.
Is the ADC voltage range -0.25V to 0.5V as well?
Thanks in advance!
Davide
Thanks in advance!
Davide
This question has been assigned within the team and will be reviewed and followed up with another application engineer when possible. In the meantime, please attach any associated log/.gg files associated with the projects
Thank you,
Alan
Hello Davide,
This is not spec'd in the current datasheet.
Jonny.
Hello Jonny,
Is this information somewhere else or would it appear in the datasheet in the future? I think it's an important information to have in order to correctly set the current sensing resistor.
Thanks in advance,
Davide
Hello Davide,
I agree, I have brought this up with the team, and this should be added to the documentation in the future. There should be a section describing the ADC accuracy similar to what we have for our other gauges.
Jonny.
