Other Parts Discussed in Thread: BQ51013, LM5102, BQ500210
Hi
I'm looking for TI Wireless Power(charger) Solution..
Could you pls recommend which is the best solution?
How about BQ500210R?, BQ51013? and LM5102?
Demand Spec as below :
Primary(1st.) Side :
Using Half Bridge Gate Drive IC in order to lead induced voltage/current at Secondary(2nd.) Side.
1st. Side will be composed of Half Bridge Drive IC,
will be operated by 12V from Adapter power supply.
induced from 1st. Side Coil to 2nd.Side Coil and then 2nd. Side Input should be 5V/100mA(CV/CC).
Secondary(2nd.) Side :
supply 5V/100mA to Charger IC, which is charging the Battery.
eric.
