I am interested in using the LM317 as a simple current regulator for battery charging (I < 20mA). The input voltage can be as high as 10Vdc max.
Any idea what the leakage current is when the input power is removed and the LM317 is reverse biased?
Charger --> LM317 --> Battery
When charger is removed it is:
Battery --> LM317
Do you have any recommendation for an LDO replacement for LM317 in a constant current battery charging application?
