Is there is an internal reverse-voltage protection diode between the Vin and SW pins (connected in reverse between drain and source of the top switching FET)?
Thanks.
Thanks.
Hi - Thank you for your inquiry. I'm forwarding your question to the Application Engineer in charge of this project.
-JPF
The Data Sheet does say that the output will not sink current which implys a reverse blocking diode. Let's see what the device engineers say.
The body diode of the high side (top) switching FET will prevent the SW voltage from going a diode above VIN.
Mike
Mike,
Thanks. Is it possible to document the body diode in the datasheet for future reference?
