We have done a design using LMZ16308 voltage regulator for powering a cell phone module Cinterion TC 65 inside a small unit that coexist with GPS (GNSS) receiver RTK high precision. The problem we get is interference in the GNSS signals from internal LMZ 16308 freq. harmonics. We have installed all combination capacitors and inductive filters from documentation and also we produce a metal shield by CNCbut we can't fix the noise. Could you tell us if you have any suggest or another voltage regulator for this application. If we remove the voltage regulator and we power the unit using Tektronics laboratory power supply system works correct. Thanks a lot for help.
Joan
