SLUU321C bq24150/150A/151/151A/152 YFF EVM (HPA256) is a single document applies to all the five ICs, and from the document it appears that the five ICs are pin-to-pin compatible.
The web comparison are almost identical. Although the form above does not mark BQ24152 as "Switch-Mode", its datasheet SLUS847A says otherwise.
Between bq24151A and bq24150A, the difference is documented in page 17 of SLUS931A in section "USB Friendly Boot-Up Sequence". However no comparison between 152 and 150x/151x is given.
What is the difference between bq24152 and bq24150/150A/151/151A?
In addition, what does the suffix "A" in bq24150/150A/151/151A denote? Does it mean "automotive" grade?
Paul
