When calculating compensation values for Buck converter(TPS54620), i found few equations,
For TPS54620,
we have Output Bulk capacitors 4, 100uf's and lots of decoupling capacitors(0.1uF or 0.01uF) near to ASIC on same rail.
Here Cout means whether we need to consider complete capacitance or only Capacitance proximity to PS54620 output node alone.
another case,
In case we have a ferrite bead and then few output capacitors, whether we need to consider Capacitors after Ferrite bead also.
