Hi
My coustomer current using TPS53014/5.
Can I teach me below quastion.
How to calculate the value of Vtrip in the Table①
masa
Hi
masa
Hello Masa,
Vin = Input voltage
Vout = Output voltage
L = Inductor value in Henries
Fsw = switching frequency (should be 500kHz)
Rdson = On state resistance of the low side MOSFET
You then pick your over desired over current limit and then solve for the Vtrip and the select the proper resistor value that fits the desired limit. This resistor then goes between the DRVL and PGND pins.
