I'm trying to build a high side switch cut off for a Li-Ion battery pack using a voltage monitor IC and a PFET. I've proved that the theory works with a TPS3837, but obviously as the battery is disconnected from the load the voltage comes back up and the FET is enabled again.
Is there a similar part that latches? I can't find one.
I'd actually be interested in adjustable voltage set level if it existed also.
G
