Have a customer trying to better understand the relationship of the Current Limit threshold versus opterating temperture of the IC. Here is the CL threshold data they have collected:
- 5A at 27C
- 3.3A at 70C
- 2.4A at 85C
They have conducted tests make help understand the behaviour of TPS40055 at temperature.
One characteristic was that the pulses broadened slightly near CL.
Another characteristic was the increase in phase lag between the beginning of the pulse and the Scope trigger.
One other characteristic was the increase in the negative excursion of the noise voltage of the LDrive (Pin 10) at the beginning of its pulse (i.e. turn-off of the HDrive) - but this was in the nano-seconds timeframe. Not sure if the device was actually current limiting, or else it was thermal limiting.
Monitored the IC surface temperature, but again there was no big revelations between low current and high current - about 8C degrees rise in both cases.
