The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LM3017 with high capacitive load
Other Parts Discussed in Thread: LM3017
Hi E2E,
we are investigating the LM3017 for a 5V2 to 22V boost converter for external sensor supply.
Output current shall be limited to max 200 mA.
We are using the LM3017 evaluation board an modified the Rsen resistor and the inductor.
But we have a problem to drive capacitive load in the order of 1000 uF. The controller goes into a SC latch-off state, and needs a "reset" via the EN/MODE pin.
Does any one know an easy way to charge these large load capacitor, and in the same way limit the output and short circuit current ?
In the LM3017 the softstart timing periods are fixed, although we could accept a much longer start-up timing.
Jens Soelvstrom Jensen
