Hi team members,
Is correct parameter of R10 in TPS53014EVM-126 ?
This parameter is set for Vtrip. Vtrip is select from Table 1 (OCL registor values) in datasheet.
EVM's value(15.4K) is not in Table 1.
Kenji Itoh
Hi team members,
Kenji Itoh
The datasheet is not clear about that. Some circuits set discreet values based on current thru the resistor, others are continuously variable. I'll try to look into this, but it may take a long time to track down the answer. To be safe I recommend using the datasheet values. If you don't hear anything within a couple weeks post back to the forum to remind me.
