I designed a stepper motor driver card with drv8711 and csd17506. Design schematic values same as drv8711evm user's guide.
My company using this card in our products and at least 100 card worked great and there was no problem until new mosfets arrived. We get these mosfets from digikey and they look different. As i attached a photo of old and new ones you can see them.
The problem is, when i powered motor some of them burned suddenly some of them are working 1 sec some of them are working for 3 hours but all of them burning at last.
I thought about if there is a problem about components and ordered new ones from digikey again and same problem occurs. Resistance of drain and source of burned mosfets are nearly 0 Ohm.
Now i am thinking about if there is a version change in csd17506 but could not found any change only their visibility.
When i solder older ones they are working good, but new ones are getting damaged.
Whethere i am thinking about using gate resistor, the problem is both the problematic and workig well mosfets are csd17506. What would be the difference?
Should i try series gate resistor? In what value?
Note:What sould be the soldering degree of these mosfets?
Thank You
