TPS62562DRV for TMS320C6748
Other Parts Discussed in Thread: TMS320C6748, TPS62562
Hi team,
I have a question about TPS62562DRV.
Our DSP TMS320C6748 has an errata which is described from P.22 to P.25 in the following document(SPRZ303H).
http://www.ti.com/litv/pdf/sprz303h
 Currently customer is using LDO for the DVDD18. To avoid this errata, I will recommend to use TPS62562DRV as workaround.
Does TPS62562 accept the 140mA leak current form the DSP? I believe there is no problem because the leak current from DSP is less than the switch current limit of TPS62562. Is my understanding correct?
Yamaguchi
