I am planning to use LMZ13610 for my project LED Operation Theatre Light. Kindly suggest whether I should use a double layer PCB or MPCB for mounting LMZ13610. LED's will be mounted on the same PCB.
The short answer is that evaluation boards for LMZ13610 use 4 layer PCBs. You should probably plan on that as well. There is a rather thorough discussion of required heat sinking copper area in the datasheet.
