My customer is using LM3489 under the following conditions
Vin=12V Vout=6.2V Iout=1A and the sw frequency become around 250kHz.
and they changed the FET to which had a lower Rdson and higher gate capacitance
(changed On-semi CPH3355 to ROHM RQ1E050RP )
As the result, the Sw frequency was reduced to around 150kHz.
Is there any possibility that the FET specs make such a big impact on Sw frequency?
and the pin layout of these 2 FETs are different, so they jumpered between LM3489 PGATE pin and RQ1E050 GATE pin.
Actually I'm more concerned about an impact from the jumper.
Any advice would be appreciated.
Go
