Hi all
Would you mind if we ask LM2991?
On the datasheet Typical Application P1, in case of not implemented R2(R1=240Ω、Cin=Co=470uF),
this regulator doesn't work as dropper function.
So, only this regulator uses as switching function on/off like as High side switch.
And then, will it be Input = Output? or not under warranty?
Or, if you have some arecommended negative voltage switch, could you let us know it?
Kind regards,
Hirotaka Matsumoto
