I'm currently using an LM2595(DDPAK/TO-263) as a split rail design with a coupled inductor, and this has worked well so far, but its huge (Application Note 1118.pdf). I need something more compact but because I'm still rolling my own boards I cant use anything with a power pad, its just too difficult to install with just an iron.
Can you recommend some regulators that will allow me to do this. I understand the Simple Switchers are perfect for this arrangement.
I have also noticed the LM2675 comes in an SOIC package, will this replace the LM2595(DDPAK/TO-263) successfully, are there any pros and cons that will mess up my day. Also I'm not sure if this is the correct forum for the next question, but can I use any of these devices listed below in a similar way to what I have described above.
TPS5402
TPS54233
TPS5420
LM2650
Cheers
Martin.
