Hola,
I have a question about TPS2513 application as below:
If I want to use the USB port for APPLE cellphone charging and it also can work normally for USB communication at the same time.
Can I use below block diagram for the above application?Can USB port communication function work normally?
Or does TI can recommend the suitable solution as the above application for us?Thank you.
