Hi.
I would like to know about the voltage range on the EN pin for the LP3891. I would like to be able to apply a "high" level greater than VIN to the EN pin to enable the part, but the data sheet is not clear on whether I can do this or not. At first guess, you might say "NO", but I ask the question because on a very similar part (the LP3892), there is a xSHDN pin (same function as the LP3891 EN pin), and the LP3892 data sheet clearly states "The xSHDN pin may exceed VIN but not the maximum of 6.5 V". I see no statement like this in the LP3981 data sheet, but I would like to know if this works the same for the LP3981 as I would prefer to use the LP3981.
Thank you.
