Hi All,
This is my first time posting here and I am an amateur electronics enthusiast. Please forgive if I get some of the lingo wrong.
I am trying to fast charge 2 LiFE cells at 3.6 volts and 10 amps each using dual bq24630 chips.
1) How do I accomplish this? Do I have to set up 2 boards with 1 bq24630 chip each and duplicte the associated components(Inductors,MOSFETs, capacitors etc) ? and monitor the overall charging process by using a MCU?
2) How much does it cost to implement the above solution? what would be the bill of materials for the charging circuit only (not including power supply and cells) ? Please also provide a bulk cost if possible.
3) Are there any components that can be shared in the 2 channel charger mentioned above or is it best to isolate the 2 circuits?
4) How will I accomplish cell balancing? I can put some login in the MCU to wait till I get the "Charge Complete" signal from both bq24630 chips, is this the best way?
