Tida-00329
Other Parts Discussed in Thread: BQ51050B, BQ51003, TIDA-00668, TIDA-00881
I would like to try the Tida-00329 solution for wireless power plus battery charging.
Which coil value is indicated for this example? I need to use a pcb one, any suggestion regarding size, layers, traces width,...?
The battery to be charged is not bigger than 150mAh.
Francesco
  • Francesco,
    The WR222230-26M8-G coil from TDK is 27uH.  Are you using a bq51003 (power supply) or a bq51050B (with integrated charger)?
    For Layout considerations, I suggest looking at the Layout section of the bq51050B datasheet.  In general, our EVMs are build with 4-layer PCBs.  The bq51050B charge termination accuracy can have a wide distribution at low currents.  I can give more details if needed.
    Dick
  • Hi Dick,
    thanks for your reply.
    I would like to use the bq51050B with integrated charger (the battery to charge is rated 240mAh).
    The questions regarding the layout are related more to the coil, because I don't have much space and I would like to avoid to add the coil as an extern component if possible. If I use a pcb coil on the receiver side, should it be the same on the transmitter?(I was thinking to work with the TIDA-00415)
    Francesco
  • Francesco,
    PCB coils have been used, but in general tend to be lower efficiency.  TIDA-00668 is an example of a booster pack made with the bq51003 using a PCB coil.  Compare it to TIDA-00881 which uses a traditional coil.
    The TIDA-00415 uses a 20mm coil.  Using the coil mentioned in the previous post would be a good match (it is 20mm as well).
    If you do use a PCB coil on the RX side, that will not impact the coil on the TX side.
    Dick
