How is the value for Current Taper Threshold at EEPROM location 0x4e set? The value and units aren’t well documented in the datasheet.
How does the programmed value 0x12 convert to 200 mA?
Is the value fixed or does the gas gauge update it? I looked at a few packs and the value varies.
I’m working with my customer to investigate a compatibility issue with a newer gas gauge. I’m trying to figure out how their legacy design using a bq2060 gauge worked.
