I've an question about the Charge Status register (CHGSTATUS 0x01) on the TPS65010. I'm configuring the charger by default (CHGCONFIG = 0x1B) so the fast charge timer and taper timer are disabled.
The battery is charged correctly : The AC current equals 1A during the current regulation phase and it decreases during the voltage regulation phase. If I change the battery, the charger restarts automaticaly a new cycle.
But some bits of CHGSTATUS are not update: The Bit6 (AC Charge) and Bit7 (USB Charger) works correctly but the Bit4 (Term current) is never updates (value is always 0) even if the battery is full charged or replace by a other one. Do you have a idea why ?
Maybe it is necessary the reset (B6 / B7 of CHGCONFIG) the charger before start a new cycle of charge....
Thanks for your answer.
