I have a question about TPS61160.
Does TPS61160 operate normally when the dimming frequency is 256Hz?
And please tell me the minimum dimming frequency of TPS61160 when I want to operate TPS61160 normally.
Hi Takahiro
The minimum pwm frequency on the TPS61160 is 5 kHz. If you need to use pwm frequency below 5 kHz refer to the attached application note (SLVA471).
Randyslva471.pdf
