I'm working with a wearable application and am interested in using the TPS65631W. However, I see that a CTRL signal is used to program the output voltage of the inverting buck-boost converter (Vneg) instead of the common Swire protocol.
Upon inspection of the datasheet (section 8.5), I have found a few differences between SWIRE and the CTRL signal. I was hoping you could talk more in depth about these differences and how difficult it would be to switch to using the CTRL signal instead of SWIRE that is seen on most AMOLED power devices.
Hayden
