The Problem
Based on figure 5 in TPS82740B datasheet the efficiency of the regulator must be at least 50% when the load is a single digit uA. The measurements of the energy consumption with a Coulomb counter in our system shows that the efficiency is in the 10-15% range. Please help us figure out the cause for this discrepancy. Details are given below.
Schematic of the power section
Setup
Battery connector (X2003) is connected to a bench power supply (BT-305) at 4.1 V.
CTRL signal of TPS82740 is low, so LOAD is grounded.
Nothing connected to the charging connector (X2005)
The load for VREG is
A nRF51 chip and its accessory components (crystals, antenna)
A digital pot which is in low power mode (0.5 uA load).
The program running on the nRF51
switches on its radio receiver for 5 ms every 1200 ms (~11 mA)
the processor wakes up every second for about 1 ms (~4.5 mA)
The rest of the time, the SoC is asleep except for the low frequency RTC timer. (~5 uA)
Energy measurement equipment setup
LTC2942 Coulomb counter logged by a nRF51.
The sense resistor used is 2 Ohm.
Measurement 1
Placement of Coulomb counter: between the power supply (4.1 V bench supply) and the battery connector (X2003)
Measurement time: 1000 seconds
Difference between the accumulator value of LTC2942: 123
In terms of energy drawn: 0.261375 mAh
In terms of Coulombs: 0.94095 C
Measurement 2
Placement of Coulomb counter: Remove the R2118 resistor and place the Rsense in its place. This is to sense the energy consumed by the load of regulator.
Difference between the accumulator value of LTC2942: 15
In terms of energy drawn: 0.031875 mAh
In terms of Coulombs: 0.11475 C
Inferences
The LTC2942 is not accurate when measuring low current, so that will result in error.
The drastic difference in the energy measured before and after the regulator means that there is some a problem somewhere, either in the measurement or the circuitry.
Plausible causes:
The routing of the TPS regulator
The C2011 bulk capacitor is leaking too much current.
The measurement device LTC2942 is wildly inaccurate
Questions
Any pointers on how we can tackle the problem and improve the efficiency (if its not a measurement error)?
We know of the app note to measure efficiency of low Iq devices http://www.ti.com/lit/an/slyt558/slyt558.pdf Is there an accurate way to measure the energy consumed by the system, like an accurate Coulomb counter?
Can a current waveform analyser be recommended? One which has enough dynamic range and bandwidth.
