Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
BQ24165 need a confirmation
Expert 2065 points
Other Parts Discussed in Thread: BQ24165
I need a confirmation about something:
In the datasheet the pin SYS seems to be connected to the load. Hence it should normally be a Power Output, correct ?
However, inside the datasheet page8 it is labelled as a "I"
So I am confused. Can you please confirm that the output of BQ24165 to connect the load is well on SYS net.
Can you also please confirm the expected voltage to be found on the  output pin (SYS) ? I suppose it is the value for the voltage of the battery ?
