I have Altium Designer which can not import PMP7668 Design Files. The schematic has .sch extension and PCB layout .pcb however, none of the Altium importers recognize either file. What importer do I need to import these two files?
Thank you,
Silvo
Thank you,
Silvo
Thank you Brian,
I want to open .pcb and .sch files provided as you can see on the web page under "Design Files" and then click on "Download Design Files" and select "PMP7668 Design Files". I even downloaded the recommended viewer, and it can't open the files. I would like to start with accurate schematic and PCB layout in Altium environment that I can modify and then add my project to it. I did not have this type of problem with the previous downloads from TI Design Kits.
Silvo
Hi Silvo,
I've asked the design engineer to confirm the validity of the files and I'll let you know the result.
Thank you for your patience.
Brian
Hello Ulrich,
This solves the problem. I happen to have old version of PADS but not installed on my machine. I do thank you very much for taking your time to help me.
Silvo
