Hello Team
We want to design a DCDC converter. The demand is 12v input , -5v voltage and 8A output. We plan use TPS51363. i am not sure if the device can do it. Could you help double check it and give us some advise? Thank you.
You have to de-rate the current by a factor of 1-D for inverting buck boost topology. I don't believe you can get 8 A output at 12 v to -5 V conversion.
Agree with Tucker, and first, 51363 Max output is just 2V, and also we tried to change 51363 EVM from buck to buck-boost inverter, it can work, we set it 1.35Vout, and test switch node, when add heavy loading, there is double pulse happen. looks the loop is already not stable.
