When are use TPS54318 to generate 3.3V when the input voltage is 5v,the output voltage is 2.8v ,i measure the PH pin signal ,the duty cycle is 0.55,the vsns pin voltage is0.69v,the feedback resistor value are respetively 100K and 31.6k 。
Thank you for your attention
