Hi all,
I've read a thread with simil request, but the file has been sent by email (I assume). Can you please provide me with the config file to update the BQStudio software ?
thanks,
Domenico
Hi all,
thanks,
Domenico
Hi domenyko,
Actually I don't know which file you need.
If you need the latest version of BQStudio,below is the download address of BQStudio:
http://www.ti.com/tool/bqstudio?keyMatch=bqstudio&tisearch=Search-EN-Everything
You could find BQ27530 in the list.
Or have you ever run some test with BQ27530? If yes, that means you have configure the BQ27530 and you can log your config data to use next time.
Sammi Shang
Hi Sammi,
Thanks for the answer. The problem is that the BQStudio seems not supporting the BQ27530-G1. When at power up I select this part from the list of the gauge, a pop up advises that the software does not support the device.
So I was thinking that thete is a config file for the specific part.
Domenico
