Is it possible to do individual LED channel dimming by SPI only without using PWM inputs ?
Thanks Gunter,
If they are only for status and safety, they could use program the current on each channel to blend a color without PWM with 5712. 5712 could use software command to program each channel’s current. We call dot-correction. I suggest you get a EVM for customer to try.
If they needs accurate PWM dimming within the device, they could have TLC5941-Q1.
