TPS3897 - Active high is pin 4?
Other Parts Discussed in Thread: TPS3897, TPS3898, TPS3896
Team,
My customer has a question:
I’m looking at TI supervisor ICs and found TPS3895,96,97,98 series.  I need what I think is an active HIGH output (open drain or push-pull would work) and am confused by 2 different sheets of the data sheet.
http://www.ti.com/lit/ds/symlink/tps3897.pdf
Page 3 has:
Page 4 has:
If I look at TPS3897 on page 3 (Device Comparison Table), it calls this part’s output “Active high, open drain”.
But if I look on page 4, pin 4 is active high on the TPS3896/TPS3898 column.
Am I just not reading this correctly or is there an error on the data sheet?
