Hi all
Would you mind if we ask TPS40200?
When the output has 0.9V, Vin added the voltage.
And then, TPS40200 didn't output.
What should we confirm? Could you give us the advice?
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Hi all
We added the following file.
Please refer to it.
20161210_TPS40200.pdf
And then, we would like to show you our customer's circuit.
However, it includes confidential content.
Could I send it using private message?
We need your help.
Kind regards,
Hirotaka Matsumoto
Qian san
Thank you for your reply.
We sent you the customer's circuit.
And we consider that Vout 0.9 bias causes the failure.
As our assumuption, ISNS is added the 0.3V(via PFET body diode 0.9-0.6V=0.3V), VDD voltage will be less than ISNS.
So, in case of this reverse voltage, it occurs OCP protection.
Is our recognition correct?
Kind regards,
Hirotaka Matsumoto
