Whether or not the LP8758-E0EVM Evaluation Module can control output through GUI, the configuration process can save to chip?
You can control the output voltages, current limits, startup sequence etc. with the GUI. The register setup is however lost after power down, you cannot write the setup to the OTP (one time programmable) memory that is used to store the default setup.
Hope this helps.
Thanks.
Tomi Koskela
