Hi. Battery pack that we are using is equipped with BQ34z100-g1. I noticed that battery pack is charging even though the termination conditions are met.
So my question is :Does Bq34z100-g1 only use these parameters(taper voltage, current etc.) to determine when battery is full but does not interrupt charge?
The charge interruption should be done by charger or by the protection and balancing solution?
