1)looking for the components with extended temperature range (-40C…95C),like the ontroller for ORing MOSFETs (Hot Swap Power Manager, negative line, -48VDC) like TPS2350
Do we have such device with extended temp range??
2)
Please look at TPS2350 Data Sheet (page 2).
As you can see the max. operating junction temperature range is -55C…125C.
The recommended junction temperature range is -40…85C.
Could you please explain what is a max. case temperature for continuous operating mode?
What is a factor limits the case temperature?
