Dear Sirs,
Hello
I have a questions about 9.3.4.3 Interrupt to Host (INT) on d/s page 22~23.
Please advise.
Question1
I had checked NTC_FAULT by remove JP8 on EVM .
Also, I had checked CHRG_FAULT by apply >18V on VBUS terminal block J1 on EVM.
I think the Fault flag in REG09 is Latched Or NOT latched in case by case.
REG09[2:0] NTC_FAULT[2:0] , NOT latched.--> No need to read REG09 two times...?
REG09[5:4] CHRG_FAULT[1:0], Latched --> the host has to read REG09 two times consecutively.
Is my understanding above, correct?
Question 2
I did not tested following, but would you pleaase advise latched or not latched?
REG09[7] WATCHDOG_FAULT ,Latched?
REG09[3]( BAT_FAULT ) , latched?
REG09[6] (BOOST _FAULT]? latched?
Thank you for your support, and with my best regards
