We are using LMZ20502SILT to convert from 3.7V to 3.3V.
As per data sheet it is recommended to use RFBB = 53.2 kΩ and RFBT = 237 kΩ.
We cannot find 53.2KΩ of desired size we need (Size required: 0402).
So we need to change the Resistor value of RFBB and RFBT for 3.3V Vout.
SETTING THE OUTPUT VOLTAGE Formula in datasheet is as per below:
RFBB = 0.6 / (VOUT - 0.6) . RFBT
When we calculate changing Resistor value of RFBT , it doesn't give the desired voltage.
With this formula if RFBB= 53.2K and RFBT = 237K the output is 3.272932 and not desired 3.3V.
We need to know how to calculate this combinational Resistor values for 3.3V Vout
